retorquing headstuds, oil leak?
Old Feb 25, 2008 | 02:07 PM
tombakers's Avatar
Default retorquing headstuds, oil leak?
alright chaps,i have completed a engine build on my civic and am happy with the result, im runnig a turbo at 0.9 of a bar and areinforced block ieGE blockguard, eagle rods and wiseco pistons. everthing was good till i noticed a oil leak from the left front oil galery on the headgasket, im thinkin do you need to retorque head studs after so many miles or is it my block guard that is flush pshing that side the head off its oil seal. hope this makes sense, manythanks
here is a pic of the block before the head wasput on, the oil galery is the one at the top left.
[IMG]local://upfiles/16048/688D0029F61B4643A600C10F4A59D33D.jpg[/IMG]
Old Feb 25, 2008 | 02:20 PM
riceburner700's Avatar
Default RE: retorquing headstuds, oil leak?
are you running arp headstuds? if so retorque them down and the leak should go away
Old Feb 25, 2008 | 02:35 PM
tombakers's Avatar
yeah running arp studs! the oil leak is very annoying, its loses quite a bit. will try and sort that this weekend and i have a new uprated timingtiming belt to go on it will be a good time to do that. does anyone have trouble with the vtec hydraulic lifters cause i have a tappy noise coming from my head and have gone round and checked all valve adjustment and there perfect the only thing i can think of is the hydrailc bit in the middle, when i went to the tuners for my mappingthey said the noise wascoming from the oil filler area. after usingthere listeningequipment. is this commmon afterrebuild to have a dodgy hydralic lifter?
Old Feb 26, 2008 | 10:20 PM
MY99SI's Avatar
when i put studs in my b16 a while back i always go a few ft/lbs over just to be cautious
theRDRman
Nov 28, 2011 04:18 PM
oilltd
Jun 10, 2008 04:06 PM
mokijo2
Dec 27, 2007 12:11 AM
Pete
Aug 17, 2005 09:07 AM
