rev but wont go over 2k
Old Jul 19, 2007 | 04:58 PM
1c1v1c1's Avatar
Default rev but wont go over 2k
so i have a b16 obd2 in my 97 dx hatch....it fires up and idles good...but it wont rev over 2k it just falls on its face...
Could it be a vaccum hose?
Any Ideas as what this is?
Old Jul 19, 2007 | 05:00 PM
ej6buddy's Avatar
Default RE: rev but wont go over 2k
what ecu do you have, and are you throwing and cels? can you give any more information to help?
Old Jul 19, 2007 | 05:35 PM
1c1v1c1's Avatar
yes im throwin the following codes
throttle position sensor
intake air temp sensor
idle air control valve
Old Jul 19, 2007 | 05:39 PM
ej6buddy's Avatar
usually when you order swaps, a bunch of sensor will break or **** out on you during the shipping or in the warehouse. try and fix the codes, then see if you still have a problem. you could try and reset the ecu and see if you can rev up to 2,000 before the lights go back on (might work).
Old Jul 19, 2007 | 05:42 PM
1c1v1c1's Avatar
how do u reset the ecu?....
and what lights?...dash?
Old Jul 19, 2007 | 05:44 PM
ej6buddy's Avatar
unbolt the battery, let it sit for a while, it will clear the cel you're getting. and when i said 'lights', i meant the 'check engine' light.
Old Jul 19, 2007 | 07:06 PM
1c1v1c1's Avatar
thanks for the help...she purrs now.....she runs good...
Old Jul 19, 2007 | 07:47 PM
ej6buddy's Avatar
anymore cel's?
Old Jul 19, 2007 | 07:57 PM
1c1v1c1's Avatar
the only one is the intake air temp sensor
but i dont have it on the engine so i dont really need to worry about it right?...
Old Jul 19, 2007 | 08:05 PM
ej6buddy's Avatar
you don't have it on the engine as in..........the motor is missing the sensor, or the motor doesn't come with one?
