Timing belt too loose on d16y8
Well after determining that my timing belt is too tight on my d16y8, i went through the process of adjusting the tension from what the manual says to do. After i tightened the adjusting bolt i thought i was all set but now it is way too loose and when i crank it the right side becomes loose and the right side becomes tight. When i crank it again the left side becomes loose and the right side becomes tight. I went through the process again and it still does that. When i push on the right side i can see the spring moving. Can some one please help on what to do? Also is there any way to fix this with out removing the bottom cover, i already have the top cover off.
The "right side"
The left side
The "right side"
The left side
i just put a new timing belt in and water pump and the spring is on, i can see it moving, i got to where it is tight again but i dont think it is perfect, because i still hear some noises coming from the left side of the engine that dont sound normal
honda_farmboy
Jun 15, 2009 03:07 PM
