Adjusted timing belt according to book. Too tight?
Old Jun 14, 2009 | 05:05 PM
honda_farmboy's Avatar
Banned
Default Adjusted timing belt according to book. Too tight?
I adjusted the timing belt as follows.
1) Put engine on #1 TDC.
2) Loosen tensioner pulley
3) Rotate camshaft counter clockwise 3 teeth.
4) Tighten tensioner.
And the belt seems really tight between the crankshaft and camshaft. On the other side between the cam and water pump it is OK. When I say tight, there's maybe 1/2" of slack either way when I push it. With the old belt, it seemed pretty loose but never gave me problems reving up to 7K on the tach. Am I alright here?
Old Jun 15, 2009 | 09:08 AM
Sounds good. Just trust the spring to do it. (You would turn the crankshaft in step 3, not the camshaft). It should be taut on the front side because that is the part that is pulling the cam around. If you have the belt too tight, it will make a louder than normal whirring noise when running.
I like to then turn the engine a full 2 turns by hand with the tensioner locked down, to make sure the timing is right and the valves aren't going to crash. The marks should line up again after going 2 turns of the crank.
Old Jun 15, 2009 | 03:07 PM
Banned
Thanks!
And that's what I meant, I guess I turned the crank 6 teeth to get the cam to move 3 teeth.
ridethelightning93
Nov 10, 2011 07:41 AM
willowcairns
May 30, 2010 08:07 PM
burgernuds
16
Sep 21, 2008 05:34 PM
gsumano
Mar 3, 2008 07:41 PM
