turbo or na?
Remmy, I can reassure you that a marine unit will definitly not work and just be a restriction...and EVEN IF you spin it fast enough to give you any gains you WILL destroy the unit. My question to streetfreakz actually had some ground behind it. I work with high volume fans and other such equipment and I can tell you that either aluminum or plastic fans in the marine units will desintegrate at such RPM where you would theoretically see a gain. Not so much from the speed, but from the fact that they vobble a lot (think of an LS-VTEC). In order for the unit to be reliable and actually work the blades/shaft/bearings must be made with very little tolerances... I still don't think that this unit is worth the money, but using a marine unit will definitly just hurt performance...
i like the pic of the little blower you put up. there are alot of problems with that unit, not fast enough, very low rpm range. no over heating protection, it's made from mono urethane plastic with a heat range of 175 degrees tops, no protection on the inlet side from large debrit or personal injury protection, the motor cannot be rebuilt unless it's completely torn down, and the fan is plastic, and theres no adapter on the front for your filter or inlet tube. it also has no warranty, money back guarranty, or any hp gain guarrantee. so by all means get one. oh and by the way, there are NO bildge pumps over 250cfm. as for the question on my units cfm, it's 803. and go ahead and test for the psi with my unit, you will be disappointed, no more than 2psi max. and yes, please do the comparison between the jackson supercharger 6psi and under with my unit. lets say the 6psi system beats it by 25hp, so what. just add a second e-turbo and beat it. and it will still be over $1500 CHEAPER. go ahead, we have nothing to hide, we know they work, and they have been dyno proven to work. so go ahead and talk all the smack you want to. i will love to prove you wrong. anytime anywere. BRING IT ON!!
