type r cam vs skunk2 cam
Old Jan 9, 2005 | 06:00 PM
Dickie's Avatar
Member
Default type r cam vs skunk2 cam
hey, sup guys, i gotta question for those of u that know about the type r cam and the skunk2 stage 2 cam. which is better on my b18? is there disadvantages on either one? specs maybe?
any help is greatly appriciated, thanks guys
Old Jan 9, 2005 | 07:29 PM
sacicons's Avatar
Default RE: type r cam vs skunk2 cam
on stock valvetrain, the stage 2 is a bit much, eventually the valvesprings will get tired and begin to float, causing severe engine damage. the type r cams will give a nice boost in performance, but the S2s will about double the gains of the type Rs. also, the S2 stage 2s are made pretty much exactly for brag racing, if thats what you plan on concentrating on, then its a great setup. if you want to do any kind of circuit or track (not drag strip) racing, then look into some Toda Spec Bs. theyre more expensive than the skunks, but give a broader pwerband as well. but you will also need to upgrade the valvetrain with them as well. oh yeah, and all this is assuming the B18 you have is the B18c1. because if its a non-vtec b18a or b18b, they wont work. and if its a B18c5, you already have type r cams.
Old Jan 16, 2005 | 01:53 PM
Dickie's Avatar
Member
so if i decided to go with the toda's, and upgraded my vavletrain and whatnot, how would that wear on my engine? or would it (it is a b18c1). also, is this cam a pretty good allround cam? or does it do really ****ty in a few areas? im gonna keep searching, thanks guys
Old Jan 16, 2005 | 05:56 PM
sacicons's Avatar
the Toda cam is a great one. it will wear a bit rough on th evalvestems, but if you upgrade them along with the springs and the cmas and retainers, then its not a big deal. of course it will cause a little more wear on the engine itself, due to higher cylinder pressures, but not a huge amount.
skibum853
Sep 24, 2007 07:53 PM
ProjectGSR
Feb 11, 2007 12:26 AM
civicblend97
Apr 29, 2006 01:12 AM
JDMracer00
Nov 9, 2005 09:40 AM
Pete
Oct 13, 2005 11:32 PM
