Underdrive Pulleys
I was reading a different thread and many people were saying uderdrive pulleys aren't a very good modification. I was thinking of getting one for my turbo civc, is it not a good idea? Whats so bad about them?
Inline-4 engines aren't naturally balanced. When they go through a full cycle, there's some slight vibration. At higher rpms this is a lot more noticeable. To offset this, most I-4 manufacturers add weight to certain areas of the crankshaft to balance it. The crankshaft pulley, attached to the end of the crankshaft, is probably included in the crankshaft balancing. Changing the weight would very likely change the crankshaft balance (and perhaps lower your actual max rpm).
Why wouldn't a car manufacturer make the pulley smaller if they could? It'd cost them less materials to make in the first place and they'd deliver a product with (1-2 hp) more power. There's a balancing reason behind this, and I wouldn't be one to question Honda on it.
If you want added performance, look into weight reduction. If you strip your car down of the soundproofing in the doors and remove carpet, you can lighten up your car by several 10's of lbs. This will improve acceleration, braking, and handling. It'll also cost you nothing more than some elbow grease
It won't impact the durability of your car, though removing soundproofing might make it a little noisier to drive.
i had a light weight pulley on my car and the damn thing was a pain in my a$$. Had to use a chain wrench and 3 foot breaker bar with a 4 foot pipe attached to it. It helped a little but not the cost of a new oil pump that almost went out. Unless you get a fluidamper i wouldnt get one, they just spell bad news
Onlly have 1/4 tank gas at all times, the weight you have just shaved off is going to net you free hp. Ever had to lift a gerry can with 35 litres in it? Its heavy as ****.
http://crx.honda-perf.org/articles/battrep/battrep.html
"If you consider that every six pounds of weight you save is equivalent to one horsepower, you can see where simply loosing some of that battery pork could help the performance of your Honda, whether you're driving on the street or the track. "
Using these numbers, stripping that interior could amount to between 6 and 12 lbs, which would be equivalent to the 1-2 hp that the underdrive pulley would give.
therickus
Feb 20, 2008 10:54 AM
therickus
Feb 20, 2008 07:47 AM
top99sir
Jan 6, 2006 07:43 PM
