Valve Cover painting and installing
Old Jan 2, 2008 | 11:03 AM
  #21
corsair8080's Avatar
Default RE: Valve Cover painting and installing
Oh thanks for that its a helpful diagram
Old Jan 2, 2008 | 11:30 AM
  #22
mcmichael13's Avatar
ORIGINAL: corsair8080
Yeah i dont think its a big deal, its the valve COVER
One of my buddies is like " youll be driving down the road and your cover will blow off because of extreme pressure..."
I dont know, ill see when it happens
I just cant wait to paint it gloss red
yeah thats true because there is ample room in the engine bay for that to go flying off... and to believe the lack of appropriate torque can cause extreme pressure under the valve cover is hysterical. i've taken my valve cover off numerous times and never used a torque wrench... just tighten them appropriately... use a smaller wrench so you can get a good feel... the longer the wrench the easier it will be to turn at higher torque specs... torque = force * perpendicular distance... so the farther you are with the same amount of force the more torque you will get at the bolt. i'm just saying this so you dont use like a 1/2" drive wrench so it feels easy to turn and you end up shearing the bolts. use a small wrench and get them snug
Old Jan 2, 2008 | 02:15 PM
  #23
Alright thanks, i finally hear some one tell me that they have taken theirs off WITHOUT a torque wrench
i feel better thanks guys
Ill tell ya how it goes
Old Jan 3, 2008 | 10:46 AM
  #24
SovXietday's Avatar
Wow guys seriously? 3 pages about putting a valve cover on?
5 bolts, pop them off, pull the cover off. Clean it, paint it, let it dry. Put the gaskets back on (you don't need new ones unless the old ones are shot) and bolt it back on. Either use a small socket wrench or a 10mm screwdriver, it only needs like 8-10lbs of torque and they will snap very easily if you aren't careful so once they feel fairly tight it's good.
Don't make it harder than it really is guys!
Old Jan 3, 2008 | 11:33 AM
  #25
Hey, i just asked if i needed a torque wrench or not. Jeeze
I got it, im good
Thanks guys
addiction2bass
Oct 9, 2009 03:25 PM
mill$civic
Oct 31, 2005 06:25 PM
dalifts
Sep 13, 2004 11:16 PM
dalifts
Sep 13, 2004 03:33 PM
