valve springs?
what can i use in order to compress the valve springs so i can take them apart from the valves? do i need to special tool to compress them or can i use something else? please let me know. i have taken my y8 head completely apart for a good cleaning and this is all thats left.
yea there is a valve spring compressor, its a little special tool.......not too expensive......hell if ur goin to take em out why not just get a set of springs and retainers and some cams?
is that a vtec head? the normal valve spring compressors will not fit around the spring there is no room, the tool that is used bolts in , and takes place of the cam and gets bolted in for leverage. s why i finnaly gave in and just took it to shop.
no, there is no room for it, the norm is just like a gear puller, its supposed to go and latch the spring then you draw the bottom to the top. but the valves are too cramped, it just will not fit, asnd the proper tool probably cost more than the shop time
Ramyswar
Feb 4, 2012 05:09 PM
SinisterCivic1
Mar 31, 2010 11:42 AM
tuong
Apr 27, 2008 02:35 PM
tuong
Apr 16, 2008 11:28 PM
