vtec
check the new members area. theres a video on Vtec in the stickies. basically, in a car without vtec or something like vtec, your cams are set up for performance in lower RPMs or higher RPMs. what vtec does is in the lower RPMs has it set to work in lower RPMs, but when you move to the higher RPMs the vtec kicks in and adjusts the timing for performance in the top RPM band. it also adjusts the lift of the valves. im not sure exactly how it works...but thats the general concept of it.
