vtec head.
Old May 21, 2007 | 11:58 AM
AaaronF's Avatar
Default vtec head.
just a question, dopnt know if i'm going to do it or not, but how much do you guys think it will be to do a head swap, and put a vtec head on there. and does that take my head from sohc to dohc?
Old May 21, 2007 | 12:17 PM
cderalow's Avatar
Default RE: vtec head.
ORIGINAL: AaaronF
SOHC to DOHC = NO
there is no way to turn a SOHC Honda motor into a DOHC honda motor
Old May 21, 2007 | 12:23 PM
AaaronF's Avatar
oh okay. i wasn't sure. so puting a vtec head on my sohc puts a lot of strain on my engine right? will it destroy my engine, or do you think it will be able to handle it?
StifflersMom's Avatar
Cat Fuсker
ORIGINAL: cderalow
ORIGINAL: AaaronF
SOHC to DOHC = NO
There is, but we won't go there.
Old May 21, 2007 | 05:17 PM
danomatic93's Avatar
June 2010 ROTM
putting a VTEC head on a non-VTEC civic is done all the time. Search MINI-ME swap. That's what it's called. The cost will vary but here is what you need will appox. prices:
VTEC head: 150
VTEC solenoid: 50
Distributor: 50
ECU: 100
Optional: d16 (VTEC) Intake Manifold: 100
If you do it yourself, labor if free.
If you go somewhere else, well, idk
Oh, and yeah, you can't make a SOHC a DOHC, unless you swap the entire engine.
Old May 21, 2007 | 05:20 PM
FlipHKD720's Avatar
the VTEC onto a non-VTEC SOHC swap has been done quite a bit, so its very possible,it'll be about $600-$700 i'm pretty sure, and IMO i'd just stay non-VTEC and use that money for a turbo kit
and the SOHCto DOHC is actually possible, but its compltely custom and like Gene said, lots not go there
Old May 21, 2007 | 06:29 PM
Cat Fuсker
I don't know about the astronomical figures of a mini-me swap, I could shop around and have all the parts needed including a converted P06->P28 ECU around 200
Old May 21, 2007 | 09:34 PM
June 2010 ROTM
wow roto, I'd love to see where you're getting the parts from. I'm from Wisconsin and I've gone all over to find parts and they're always gone or cost an arm and a leg.
Old May 21, 2007 | 09:45 PM
June 2010 ROTM
you'll need a different timing belt too, sorry forgot about that. 50 bucks new.
Old May 22, 2007 | 04:00 AM
Cat Fuсker
just a little patience and keeping a close eye on ebay and junkyards. I actually get called when a nice honda gets dropped off at my local yard cause I'm friends with the guy:-D
