wanna build up my mini me swap..what can i do..?
if you can help me out it would be grea..i already got headers and full exhaust and intake i got a p28 already ..jus trying to see what else i can do ..lmk
bump if view new to this forums
well see that would be the purpose of your own research. we have many stickies on the subject. The Internet is a veritable wealth of information and its all at your fingertips. if you cant take the initiative to at least build a foundation of standard knowledge on which we can then build upon, then why would we want to help you. If you want help you must first help yourself.
Read first then come back with any questions. I will be more than willing to help in anyway possible.
check out "Maximum Boost" by corky bell.
PM me if you want a downloadable copy
you can install a liteweight flywheel i have one on my b16a and it climbs rpms real fast.
you can install a cam.
you can instal msd ignition system.
are you looking to do a turbo kit in future?
you can install high compression pistons
you can shave the head and have it ported
you can install a d16y8 head gasket(thinnest stock gasket gives higher compression)
you can put a 50 shot wet nitrious kit on it.
there is alot you can do
there is soooo much that you can do; but, you should set a goal and then work towards it. we can help you along the way but we cant tell you what to do.
hello new to the site but i have a d15b7 block stock internals but pulling them out i want to make around 350hp boosted price doesnt matter cuz car isnt driven yet but i want to make 350 and daily drive it thinkin about puttin a z6 head but i heard you can also use A Y8 HEAD IS THIS TRUE and whats the diff between the two? any suggestions on specific rod h beams and pistons i should use for block and should i get head ported and polished and build it and any suggestions on what i should use for the head thanks guys and i appreciate all comments pm me also if interested first time building a motor doing all labor my self except tune port and polish. so i get the motor bored and to what mill? thanks again for the help
https://www.google.com/webhp?sourcei...nd%20y8%20head
Wish I could help you out more with the other questions, but I never went down that path before so I won't comment
turbo speeder
Jan 28, 2009 03:57 PM
SovXietday
Feb 12, 2007 11:55 PM
Street Sniper
Jun 23, 2005 05:18 PM
