what all do i need for b20 swap?
i have a 92 eg coupe and i want to go b...so what all do i need. i found a b20b 97-00. i kno i need axles mounts b18 tranny si shift linkage but what ecu should i run and do i need the obd2-obd1 conversion harness? let me kno everything i need to kno so i can have a reliable b20....thx
i would suggest if you are doing the swap make it simple dont go for a b20, go for a obd1 b18 or b16 it would all be plug n play stuff, just get complete engine and harness,axles, trans you can get any b16,b18,b20 just depends on the gear ratio you want. then get mounts,shift linkage from a teg or 99-00si civic and obd1 ecu. if you get a b16 or a b18c1(gsr engine) then all you gotta do is run a few extra wires to the new ecu for vtec.
I have a full full b20 swap for your civic. Mounts, tranny, ECU, axles, etc... PM me if interested.
I just wrecked my B20 Del sol so the full engine is there and running. I will ship everything needed for swap.
edit: Nice Signature BTW check out Lecrae's [Christian Rapper] new song called Far Away. Beast, actually has the same quote in it I believe.
http://www.youtube.com/watch?v=0rerU_NYwD8
redridinhood
12
09-12-2007 04:48 PM
