what's the best swap for a 92 civic HB
Old Apr 27, 2005 | 08:06 AM
civicpsycho's Avatar
Default what's the best swap for a 92 civic HB
in terms of direct replacement, power, value etc...
thanks
Old Apr 27, 2005 | 08:32 AM
sacicons's Avatar
Default RE: what's the best swap for a 92 civic HB
a b16a is the best value. its an easy swap. and has a ton of potential. how much do you have to spend?
Old Apr 27, 2005 | 03:00 PM
jdmekb16's Avatar
yes. b16 is good choice. www.hmotorsonline.com
sirII full swap is 2200 plus shipping
allow yourself maybe an extra 1000 on top of that to do flywheel, clutch, water pump, timing belt, cams and get yourself on the road
Old Apr 27, 2005 | 09:22 PM
i'm just getting info, i don't have money allocated yet. i need to take care of body work and replace drivers seat first.
Old Apr 27, 2005 | 09:23 PM
what is a full swap, does that mean everything is included. why would i need extra for pump, cam etc... this isn't part of the swap. thanks
Old Apr 27, 2005 | 09:30 PM
sacicons's Avatar
the water pump and clutch and stuff are just planning ahead. if you have the motor sitting on the floor, its a 45 minute job to install a new flywheel, clutch, pressure plate, water pump, timing belt, and tensioner pulley. if its in the car, its more like 12 hours at best.
Old Apr 27, 2005 | 09:37 PM
gotcha, thanks. does it make sense to buy and engine and store it away, until you get everything you want and then install, or are there rubber or other parts that'll suffer from sitting?
Old Apr 27, 2005 | 11:38 PM
LEVIII's Avatar
where are you located? I have 94 SirII B16A that is just sitting on an engine stand.
Old Apr 28, 2005 | 07:33 AM
i'm in new york, but i don't have the cash yet, i'm just doing info gathering at the moment. but thanks very tempting.
btw- as i asked above is it safe to store an engine or will it need to be torn down if sitting too long, thanks
Old Apr 28, 2005 | 10:19 AM
LEVIII's Avatar
OH, Im in Cali. I think shipping would be a little outrageous
