y7 injectors with y8 intake
Old Nov 28, 2006 | 10:38 PM
civicblend97's Avatar
Default y7 injectors with y8 intake
i put a y8 intake on my y7 motor months ago i used the y7 injectors though.
ive seen some things saying that the y7 injectors are 190 and the y8 is a 240 but i never found any thing that said it for sure. if they are bigger id like to change them so it might run a little better
does anyone know if there different. when i run it hard it just smells bad i was worndering if its not getting enough fuel at high rpms. my fuel filter needs to be changed to
Old Nov 29, 2006 | 04:24 PM
BillyB98's Avatar
Default RE: y7 injectors with y8 intake
i was told it was fine to run the y7 injectors and fuel rail on the y8 mani
Old Dec 8, 2006 | 09:21 PM
tools52's Avatar
i'm doin the same swap and i'm using the y7 rail & injectors. if you're reusing the y7 computer (P2P), you don't want to use the Y8 injectors b/c you'll run too rich. you could run the y8 injectors if you mini me swap to a y8 head or get engine management.
sjmcgarrah
Aug 28, 2007 01:53 PM
strtballer98
May 20, 2007 08:39 PM
nightrider46
Aug 23, 2005 03:42 PM
dmsteele92831
Oct 6, 2004 08:47 PM
98brokeassvtec
Aug 23, 2004 05:31 PM
