Fuel Economy Discuss tips and tricks for better fuel ecomony.
Tips for optimus mileage please...
Old Jan 27, 2012 | 08:13 AM
dishjuarez's Avatar
Default Tips for optimus mileage please...
I have a civic 98 lx, automatic
i changed the spark plug for double electrode
changed spark wire
changed oil filter
changed oil
changed air filter
changed fuel filter
changed cap distribuitor
cleaned injectors
changed thermostat
changed ignition coil
tire is 32 psi
But.....
Have only 19 mpg, dont have anything codes, the only thing that worries me is that when it stopped in D4 with the engine running of course, the car shakes a little...
Thanks for all
Old Jan 27, 2012 | 02:46 PM
Ramyswar's Avatar
That's so hard to believe(not saying I don't believe you), how are you calculating gas mileage?
Old Jan 27, 2012 | 03:44 PM
dishjuarez's Avatar
We charge 10 liters (2.64 gallons), and initializes the counter, the miles that are divided among the 10 liters (2.64 gallons)
thanks
Old Jan 28, 2012 | 06:02 AM
Ramyswar's Avatar
Its not accurate like that. What you have to do:
Fill the gas tank all the way full.
Reset the the counter
Drive until tank almost empty
Fill tank to full
Divide distance by how much you filled.
Old Jan 28, 2012 | 08:45 AM
dishjuarez's Avatar
Fill tank to full
Okas, in 98 civic lx which is the fuel tank capacity?.
Old Jan 28, 2012 | 08:48 AM
Ramyswar's Avatar
The capacity does not matter. The only thing that matters is distance traveled divided by volume used.
Old Jan 28, 2012 | 08:50 AM
Ramyswar's Avatar
Rate=distance/volume
Old Jan 28, 2012 | 11:37 AM
Check the spark timing, it is adjustable. A retarded spark timing will kill gas mileage. If you can't get the spark timing right near the center of the adjustment range, the cam timing may be wrong (timing belt skipped). That is also bad for mileage and performance.
Conventional spark plugs or single-electrode platinums are fine. Some people have had trouble with multiple-electrode plugs.
Old Jan 28, 2012 | 12:56 PM
MaximusFunk's Avatar
might wanna try a valve lash adjustment. do you hear a ticking sound for a few minutes after you start your car, even in warm weather?
valves out of spec can cause bad gas mileage, loss of power, and rough idle as you mentioned.
Also, might wanna try some gumout complete fuel system cleaner to clean out your injectors and intake valves. cant hurt to try for the price.
Also, is there a lot of crap in your trunk and back seat? more weight equals worse gas mileage. a couple hundred pounds of junk in a civic can make a big difference.
Old Jan 29, 2012 | 04:09 PM
dishjuarez's Avatar
thanks, I'll check that ...
