02 civic si dash lighting problems
hey again my civic si dash light went out behind the speed omiter i wondering what fuze that is or if ill have to replace the whole light and how can i do that. also how the hell do i get to that lmao thanks guys ill be wateing
-joe
-joe
My guess its a light.
You have to pull the cluster out to get to the bulb.
Tool: all you need is a small Philips screw driver
First, if you have a removable steering wheel remove it, if not tilt your wheel all the way down
Start off by gently pulling the top part of the black cluster trim
Then work your way to the bottom corners
Now remove the 3 screws with the Philips screw driver, one at the top middle and 2 at the bottom sides
Now pull the whole cluster forward a little and tilt I forward
And remove the 2 male plugs at the top
And your done
Here is the back the bulbs
I stole this from another site.
And your done
Had to replace the bulb for the temp and gas gauges. Very helpful info. Thanks a lot.
One thing, though. In the photo of the rear of the gauge cluster that identifies what each bulb does, I believe that the bulb labeled "spare bulb" is actually the bulb that illuminates the "cruise control" indicator.
EightyNineDX
Jul 14, 2007 08:18 PM
yamahaSHO
Jun 14, 2006 05:36 PM
91_Si
Oct 19, 2004 11:15 PM
