1998 A/C Condensor or Compressor?
I have searched this web site for information on how to determine which component of my A/C unit crashed today but I cant find it. I have obviously have no clue on how to determine which part died but everything seems to work except it doesnt blow cold air. When I was driving home I thought I lost a belt but that wasnt the case because it ran just fine and all checked out fine. When I got home for the first time in its life I had a small leak of what I would call clear like oil. My guess is its the compressor but I have no clue. Any help would be greatly appreciated.
Thanks
Thanks
The A/C compressor is located directly below the power steering pump. Both have their own drive belt. The condenser is situated next to the radiator and has its own fan. Where precisely do you see a clear liquid leak? Post a photo for clarity.
When you push the A/C button, does it light up. If so, does the compressor clutch engage and does the condenser fan run?
the leak is below the compressor. The A/C button lights up. Im assuming the compressor clutch engages because when I turn the switch on the RPM on the engine slows. I will check the fan for sure. I was just thinking (maybe I shouldnt!) that when the compressor went out in my fridge at home I had a small leak of oil. The leak is right under the radiator towards the engine block.
Yes, the compressor contains a special oil that may be leaking. Just make sure the leak is coming from the compressor. When the A/C button is pushed with the engine idling, check under the hood for whether the A/C compressor belt is turning the compressor pulley. It sounds like the compressor blew and needs to be replaced. Inspect the unit carefully. I suspect that if you were to check, the refrigerant pressure is nil due to a leaking compressor.
bigmikew1
41
Mar 15, 2010 09:33 AM
addiction2bass
Aug 22, 2008 03:32 PM
hiredassasin19
Aug 18, 2008 04:46 PM
