2009 Si upgrade question
Old Oct 21, 2014 | 05:18 AM
Mnealp33's Avatar
Default 2009 Si upgrade question
I have an 09 Si 4 door I want to play with, have the cold air intake and working on the exhaust, I'm thinking magnaflow and turbo in the not to distant future. My first question is will the K20 handle 8-12 lbs of boost without internal upgrades? Also will the stock injectors, with the right mapping handle it, or should I replace the injectors
Old Oct 21, 2014 | 11:09 AM
psi means absolutely nothing. 8psi through a mcd's straw will be a different amount of air when compared to 8psi from a turbo.
Figure out how much money you want to spend, and how much power you want. Otherwise, you are wasting money and time. For example, that intake you installed will need to be removed and replaced with intercooler piping once you are turbocharged.
I am sure the K20 block and hold 300whp no problems, but I do not have personal experience with this. Stock injectors will most likely need to be upgraded.
CvcSi2008
Nov 9, 2013 09:03 PM
etsherman
Sep 25, 2011 12:44 PM
Stumasters
Mar 19, 2007 01:59 PM
YankeeFan
Dec 13, 2006 12:11 PM
bondrey
Sep 23, 2005 03:18 PM
