3rd brake light help please!!!!!
Old Dec 19, 2006 | 05:28 PM
dice2785's Avatar
Default 3rd brake light help please!!!!!
hey howz it going, i noticed that my 3rd brake light on my honda civic wasn't working. so i took the brake housing out and found that the bulb was blown. now i thought that was the problem but when i put a new bulb in it still didnt work i check the fuses there all good. so can someone please tell me what the heck is going on.[:@]
Old Dec 19, 2006 | 10:03 PM
Fiirkan's Avatar
Default RE: 3rd brake light help please!!!!!
What kind of civic do you have? coupe, sedan hatch? and what year is it.. it will be easire for an answer if we know that info
Old Dec 19, 2006 | 10:49 PM
SilverSedan's Avatar
first things first, check your socket, and the wires...see if there's anything broken in there
Old Dec 20, 2006 | 01:36 AM
dice2785's Avatar
its a hatchback when i used a test light on the positive side of the socket it lights up, but when the bulb is put in the socket it wont light up so what the hells going on here.?
Old Dec 20, 2006 | 11:36 AM
Fiirkan's Avatar
ok a hatchback is a start... do you have an 88-91, 92-95, 96-00, 01-05.? either way if my knowledge serves me right, there should be two screws holding the red cover on, and you should be able to just pull out the old bulb and put in a new one.
Old Jan 2, 2007 | 11:15 AM
dice2785's Avatar
it a 94 hatchback like i said I've taken the old bulb out and when i put the new one in it still doesn't work i also checked all of the fuses so i have no idea whats giong on????
Old Jan 2, 2007 | 12:08 PM
Fiirkan's Avatar
if it was a fuse, your gauges wouldn't work too. cause they run off the same fuse. it is either the connection to the bulb's wiring, or the socket. that or you used a broken bulb lol
Old Jan 3, 2007 | 10:03 PM
Stumasters's Avatar
sometimes the connections that actualy physicaly touch the bulbs get a little rusty/dirty. A little swab with some alcohol might help, or if its a spring loaded type thing, try prying the springed sides out gently to get them to come more into contact with the bulb housing.
Haven't had a similar problem, but thats what I would try, hope it can help!
WellFedHobo
May 30, 2008 10:10 AM
havasujoe
Nov 5, 2007 04:40 PM
havasujoe
Nov 5, 2007 11:37 AM
jhsplaya08
Mar 11, 2007 04:49 PM
padresfan1988
Feb 1, 2006 05:03 PM
