96 Window regulator
My 96 civic window does this ---
http://s12.photobucket.com/albums/a209/Forty04/?action=view¤t=MOV00330.flv
Is this the regulator? If so are they hard to replace and where is a good place to get one?
I live in Phoenix, AZ.
Thanks
Yes that's the window regulator, mainly the gear drive for the motor is either hitting a stripped out section of the lift sissor gear section or the motor itself is loose and when at the top of the lift it comes away from the gears.... So yes replacing that will fix your problem, it's not hard to do, but it takes a bit of know how to make sure you put everything back right. On getting one I'd say since it's power I'd call the local dealership and see how much they want and then check ebay, when I replaced my manual units it cost me just as much locally to get them as the powered units off ebay would have been shipped (around 75 bucks) but I'd have to wait for them and then wire it all up...
ORIGINAL: rips4
Thanks
Thanks
Thanks for the information, that shows everything.
ORIGINAL: Forty04
Where did you find that video? You should be able toCLICK HEREand have all the info you need
ORIGINAL: rips4
Thanks
Thanks
Job was successful!! The instructions where perfect. I bought the regulator with motor on Ebay for $60 bucks, and it took me 45 mins to put in. The Honda shop I go to wanted to charge me $450?? They must buy the OEM part and charge 2 hours labor.
ORIGINAL: rips4
ORIGINAL: Forty04
ORIGINAL: rips4
Thanks
Thanks
97Ej8
Apr 24, 2012 04:56 PM
Rattlin_Steele
Jun 6, 2011 10:45 AM
Impulse2k1
Sep 28, 2006 09:06 AM
magiconthetire
Apr 6, 2006 10:46 AM
