advice on exhaust?
Old Feb 18, 2010 | 01:13 AM
marcpasek's Avatar
Default advice on exhaust?
basically I want to start with the exhaust for performance and add a nice little sound to my civic.
yeah some of my friends were saying get a flow master and a long pipe, that the short pipe makes kinda a weird sound.
so are those 50 dollars ones worth it at autozone or kragen or pepboys?
whats the labor gonna charge me?
Old Feb 18, 2010 | 08:49 AM
Jacototheb's Avatar
Labor will be between 50-150 dollars. The cheapest route is to have him bend the pipe for you, then take it home and and weld/clamp your new muffler or tip on, and hang it on your civic yourself. If it's a catback, it will be cheaper.
Idk, what the long/short pipes your were talking about are.
You'll get more "performance" out of a offset inlet/outlet muffler, a high flow cat, and wider piping from the header on. This will cost more though.
If you plan on turboing... save your money and put a tip on the end of a 2.5 inch pipe. Because the mufflers you are looking at produce back pressure. And you don't need any with a turbo.
Old Feb 18, 2010 | 10:21 AM
marcpasek's Avatar
thanks that helps a lot..
The only thing i'm worried about is still passing smog. I don't want to have to do it illegally (if i have to i will) but it'd be nice if i didnt have to.
Old Feb 18, 2010 | 06:51 PM
Jacototheb's Avatar
Ohhhhh, I didn't see that you live in California. Here in Missouri we don't worry about it. But good luck!
Old Feb 19, 2010 | 12:48 AM
flow master mufflers aren't really used on Civics too often.
You won't get barely any performance out of just exhaust. Also, you have a D15B7 engine, which is a pretty weak engine. If you are looking for performance, your first mod should be swapping on a VTEC head. Gains you about 25 HP at the crank and costs only a couple hundred dollars to do.
Old Feb 22, 2010 | 07:28 AM
Jacototheb's Avatar
+1
Or do a b series swap. Pretty much all you will get out of a new exhaust now is a louder sound.
FRESH96
Dec 12, 2007 09:18 AM
Jeremy102579
Dec 15, 2006 02:31 PM
sgl
Sep 16, 2006 02:36 PM
sgl
Sep 15, 2006 01:38 PM
jbsi99
Aug 23, 2006 09:04 AM
