Build Questions
So I am doing my build and would like have questions at bottom.
Here is my build so far
B18A1
Leaving the head alone I think unless I consider a valvetrain package
Arp Headstuds
Arp Connecting Rod Bolts
Arp Flywheel Bolts
Arp Pressure Plate Bolts
Nippon Piston Rings
Hondata Map Sensor
Walbhoro Fuel Pump
650CC Injectors
Cometic HeadGasket
Gates Timing Belt
Ngk Plugs
Accel Wireset
Stage 3 Clutch
3 Inch Exhaust
T3/T4 turbo kit (14psi) Shooting for 300whp
First off when doing this swap do I need the integra tranny mount and bracket ? My next question is I am looking for an alternator to fit the b18a1 and my 94 civic so any thoughts on which one I could use with having to mess with harness or anything? Thanks again
B18A1
Arp Headstuds
Arp Flywheel Bolts
Nippon Piston Rings
Hondata Map Sensor
Walbhoro Fuel Pump
650CC Injectors
Cometic HeadGasket
Gates Timing Belt
Ngk Plugs
Accel Wireset
Stage 3 Clutch
3 Inch Exhaust
turbo speeder
Jan 28, 2009 03:57 PM
SovXietday
Feb 12, 2007 11:55 PM
