Civic VX parts compatibility?
Hey everyone,
I am new to civics and I just bought a 1993 Civic VX hatchback. I am looking for used parts and I need to know which of them are compatible with other models. My main concerns are-
Driver door glass
door panel
driver side mirror
Carpet
Exhaust
I assume that the other parts I need like the window regulator handle, glove box, etc are across the board for the 92-95. So for those other ones, will 2 door coupe stuff work on my hatch? How about 4dr? What about exhaust? CV vs VX? I know Si is bigger... or at least I think I know...
Driver door glass
door panel
driver side mirror
Carpet
Exhaust
Hatches can be considered "tricky" when looking at compatibility... especially since you have a VX. I will help best as I can. I wish my 92 VX was still with me, I just didn't feel like tearing it apart to figure out what was wrong with it exactly.
Driver door glass should be the same for all 92-95 Coupes/Hatches. I don't think having power or manual windows matters.
Door panel should be the same for all 92-95 coupes/hatches. Just make sure yours is manual (assuming you have manual windows). If you have that ugly blue interior color (which I had in my hatch), I think those are hatch specific. I have never seen a 92-95 coupe with that blue interior.
Driver side mirror should be the same for all 92-95 coupes/hatches. Assuming you have manual mirrors, make sure the replacement is manual, too.
Carpet should be the same for all 92-95 coupes/hatches. See above response to the blue color.
Exhaust. Here is the tricky one. All 92-00 hatches should be the same. However, it is not necessarily true. Your D15z1 (assuming you have the stock motor and everything) mimics the 96-00 HX/CX/DX/LX exhaust set-up where the cat converter is placed in the manifold instead of after the exhaust manifold under the car (like all of the other Civics between 92-00). If you need a replacement exhaust manifold, look for one which looks like yours (cat converter in the manifold). If you need a replacement B-pipe, look for one from a 92-95 VX (or maybe CX, too), or a 96-00 CX/HX/DX/LX (coupe/hatch). If you need a replacement muffler, look for one from any 92-00 Civic hatchback.
You can convert to the "standard" (cat under the car) exhaust system by using a manifold, cat converter, and B-pipe from a 92-95 EX/DX/SI/LX or 96-00 EX Civic. Many people do this as the "new" exhaust set-up is more commonly supported by aftermarket companies. You would also need an o2 sensor extension to relocate the o2 sensor down stream. You can buy a harness for this, or cut and lengthen wires. I suggest cutting and extending as your VX has a 5 wire o2 sensor (not common) and I have yet to see a 5 wire o2 extension harness for sale. Be careful not to damage that o2 sensor in anyway. A replacement 5 wire o2 sensor will run you at least $200.
Window handles should be the same from 92-95 coupes/hatches. Maybe sedans, too. I don't have much experience with non-powered windows though.
Glove box should be the same for all Civics between 92-95. Double check on this if you are purchasing one from a sedan though. The coupes/hatches should be the same.
Let us know if you have any other specific compatibility questions. I was going to make a parts compatibility list for all 92-00 Civics, but the list started to get extremely out of hand (big) and I couldn't keep up. lol.
Awesome reply! Now all I have to do is track down all of those parts...
I am going for a good commuter car, so I'll probably stick with as close to stock exhaust as possible... I might even just weld my own.
mastertech
21
Aug 9, 2009 02:00 PM
00civiclx
Oct 18, 2004 09:55 PM
