A couple Q's about the Tip's and Trick's sticky
Old Oct 10, 2006 | 07:23 PM
pWnEdU's Avatar
Default A couple Q's about the Tip's and Trick's sticky
These questions are in reference to the suggestions made in the Tips and Tricks sticky at the top of this forum.
#1: Do I have an EGR valve on my '00 EX?
#2: Doesn't the coolant line going to the TB aid in cold weather starting? So it would only be a summer time mod to bipass the TB?
Old Oct 14, 2006 | 10:17 AM
pWnEdU's Avatar
Default RE: A couple Q's about the Tip's and Trick's sticky
TTT. Nobody has an answer? I'm sure somebody has an answer...
Old Oct 14, 2006 | 11:00 PM
mxs's Avatar
mxs
1. yes
2. it keeps your throttle plate from freezing shut, I wouldn't remove it
Old Oct 14, 2006 | 11:15 PM
ProjectGSR's Avatar
i wrote a few of those tips and you gotta know some are for the track only. theres loads of info on the net about those tips, you can research the gains and stuff and find out if they will be worth it.
Old Oct 15, 2006 | 06:31 AM
pWnEdU's Avatar
I put a breather on my valve cover last night (and painted my valve cover) and pluged up the hole in my CAI. Now I'm looking at maybe puting a solonoid on the coolant lines that would re-direct the flow around the TB when the ambient temps are above freezing. Might be a fun weekend project. I'm looking more at eaking out every last MPG than power gains.
I did a search here and on google and didn't find much info on deleting the EGR system. Are there any negative effects of doing it besides maybe throwing a code?
I'm doing everything I can to keep the air charge as cool and clean as possible...
tarheels131
Jan 26, 2009 07:53 PM
Old School
Jan 4, 2006 11:47 AM
Street Sniper
Nov 5, 2005 09:08 AM
amg6975
Aug 23, 2005 10:40 AM
Remmy
Mar 28, 2005 11:52 AM
