Engine?
Alright, I know this is going to make me seem like a huge noob, and I am kinda, but not this bad. I drive an 1993 SI Coupe (i'm in canada), so the EX for all you people in the states. Anyways, I have taken a look at my engine, and it's the d16z6, but I haven't been able to find where the VTEC Solenoid is located, and when I drive it, can't hear VTEC kick in. Any ideas whether I have VTEC or not? Sorry if I'm not supposed to ask this here. And I already read the 'Is your engine VTEC' FAQ, and I wasn't able to figure it out.
The solenoid is on the back left of your engine if you look from the front. Here is a pic I stole from the internet.
Is your check engine light (CEL) on? Does your CEL come on and then go off when you start the car?
CEL comes on, then turns off, during normal startup. It's on for about 5 seconds, maybe less. Thanks for the quick reply as well. I won't be able to check this for sure until I get home, as I am on vacation, and the Civic had to stay at home.
Well, I've nearly redlined it with windows and moonroof wide open.
and yeah, trust, I've been looking at rev vids of the ws2 on youtube, and it sounds amazing. The guy at my local shop said he could give it to me for $420, so as soon as I get paid again, I'll be going for that. Also, would you recommend a high-flow cat? or is my stock one good enough?
I recommend a high flow cat. It really opens up the sound without causing raspiness. here's what I got... it's great... bolts right up really easily.
http://store.summitracing.com/partde...5&autoview=sku
were you thinking about getting a header too? do you have aftermarket intake?
If so, the Megan Racing header available on ebay is a great buy. Just make sure to torque down the midway flange (the joint of the 2 pieces of the header) down real good and torque them again after the first initial heat up and cool down of the header and you're golden.
for intake, you can get an AEM short ram for $100 shipped on eBay. it's better to buy it than buying an ebay intake and name brand filter because it would run you around the same total cost anyway.
I'll most likely be getting a header after I get a new tranny. Synchro's out between second and third. (if you know an easier fix, let me know) I've actually just recently ordered an AEM short ram from that same shop, so it should be in a few days after I get home. Also, I don't really have any tools like a torque wrench or anything, so is there a set amount I have to tighten the bolts on the header? or just give 'er a good crank? If you can't tell, I'm fairly new to the whole car modding business, so I'm still learning alot.
