Cluster install from LX to DX
Old 01-03-2008, 03:55 PM
dchawkin's Avatar
Default Cluster install from LX to DX
Can you take a cluster from a 98 LX and put it in a 96 DX and it work ok. Both cars are manual. Just LX has tach in cluster, and original 96 cluster did not have tach. I hope for the tach to work....really want a tach
Old 01-03-2008, 03:58 PM
cyberx32's Avatar
Default RE: Cluster install from LX to DX
I think i read that you could. It would be simple plug and play.
Old 01-03-2008, 04:34 PM
Civic Si 00's Avatar
yes it will work..... just pop out your current speedometer out (unscrew it)and put on the one from the LX so you can have the same mileage reading. So you wont sit and the roll back or forward it to match the other cluster
Old 01-03-2008, 05:19 PM
Firehawk989's Avatar
Can you actually roll the 96-00 ones back? I tried when I swapped my cluster but I couldn't see any way to do it without stripping the gears or something.
Old 01-03-2008, 06:02 PM
you can do it manually through the back with your fingers you just spin it forward or backwardbut it will take a long azz time. You got to push the 1st set ofnumber from the left side. that controls everything
Old 01-03-2008, 06:39 PM
rice_patrol's Avatar
ORIGINAL: Civic Si 00
i tried that the other day when i was playing around with my stock cluster. It takes forever to roll back a few miles. I tried taking it apart but it's not going to work unless you break it.
Old 01-03-2008, 06:45 PM
FlipHKD720's Avatar
^ you can take just the speed/odometer section out of your cluster and replace the one on the other cluster. Just two small silver screws on the back of the cluster. JUST DONT TOUCH THE NEEDLES OR YOU'LL NEED A NEW CLUSTER/SECTION
Old 01-03-2008, 07:17 PM
ORIGINAL: FlipHKD720
Thats what i did to still have the exact mileage i had in my car. It was the one i took out of the ex cluster i was replacing it with that i messing around with.
jo7man4
04-07-2007 01:42 PM
gin0o0o
02-05-2007 07:23 AM
gelaty
10-20-2006 12:34 PM
1998wagonhatch
08-15-2005 03:36 PM
millertime17
06-26-2005 09:38 PM
Quick Reply: Cluster install from LX to DX
