how do i install insturment cluster with rpm gauge on my dx ???
so i need to knw if i have to wire something directly or if i can use my dx wireing harness(probly not) so i can hook up my si gauge instrumental cluster???? any help would be greatly apreciated thanks......
Pick up an EX/Si cluster off of Craigslist or Ebay or the like, so long as it has a tach, for a 96-00 Civic. Be careful that you don't get one from Canada that reads in Kmh instead of Mph.
Two screws to remove the black bezel.
Four screws to remove the cluster,undo the harness connectors in the back.
Undo the one bulb that has a wire attached to is.
Remove the clear plastic by carefully undoing the tabs.
Remove the black plastic portion of the cluster by carefully undoing the tabs.
Unscrew the four screws holding the speedometer in place.
Reverse the order for installation.
Do the same for the replacement cluster, and mount the speedometer from your DX into the cluster with the tach. This will keep the correct mileage on your car.
RedHotRider i think you should go out and do a quick DIY of that, it'd be useful, i see alot of questions posted about that, and you have it down
ORIGINAL: Mr Mobsta Man
If the cluster is for the same gen as your car it will plug right in.
Faramire
Sep 7, 2009 02:27 PM
danomatic93
Apr 7, 2008 09:54 PM
97_Civic_LX_Matt
Dec 6, 2007 06:12 PM
