this ever happen to your civic?
Old Dec 2, 2007 | 10:05 PM
Ek Dreamer's Avatar
Default this ever happen to your civic?
On a late rainy night my civic started to act really weird, it stalled really bad, sounded like alot of backfire, u steped on the gas hard and that think wasent going ANYWHERE! the only way i was able to get home was by driving really slow and even then it still did it sometime. I have a cold air intake so i tought maybe water go in themotor, the next day i bought one of those things u put in your gas tank to clean your fuel system and cleans some other things and it never did it again. 6 to 7 months go by and the car never did that, Just recently i had my car in miami at the body shop and when i broght it back it started up AGAIN so i did the same thing but this time it didn't fix it, this is the 4th day i have it back and its still having this problem, u guys have any experience with this??
Old Dec 2, 2007 | 10:22 PM
Civic Dx 349's Avatar
Member
Default RE: this ever happen to your civic?
Sounds like its getting water through your CAI. That's how the benefits of a SRI can help out. Remove your filter and tubing and clean it all up, make sure itsdry,and if you want to keep this from happening again I would recommend you shortening your tubing or getting a shorter peice of tubing so that your not sucking water in and damaging anything.
Old Dec 3, 2007 | 01:34 AM
windcalmer's Avatar
Just my two cents, but I highly doubt that you are sucking water up your CAI. It would take a HELL of a lot of water to start messing with your engine. Seriously, like a few feet of water at least.
You problem is more likely an electrical one. Does it only happen when its wet outside? When was the last time you did a FULL tune-up?
Old Dec 3, 2007 | 05:43 AM
id say pull off your distributor cap and inspect it.
if you ran thru water and your distributor is cracked water could have gotten in thier making it run realy crapy. and over time the cap can get coroded so its not leting the plugs get a good spark,
pull the 3 screws and if the points inside the cap arenot shiny and clean i would replace the cap and the rotor button as well!
Old Dec 3, 2007 | 07:45 AM
point break 92's Avatar
lol that sucks, my celica i had last year in december was doing that for a week but heavily and the engine blew... HONDA FTW!
Old Dec 3, 2007 | 08:53 AM
mill$civic's Avatar
Ya check your distributor cap, what you can also do without taking it apart is get some water and mist it on the cap when your car is running, if there is a problem with the cap your car will start running bad or there will be some small sparks.
Mechanics told me to do this...
Old Dec 3, 2007 | 10:47 AM
Ek Dreamer's Avatar
Thank you all for your suggestions
Old Dec 3, 2007 | 06:34 PM
vectra's Avatar
ya i have had the same problem... i blame my miles.... 255,000 miles and still running
Old Dec 4, 2007 | 03:34 AM
Inspect dizzy cap (probably just needs the seal replaced), grounds, wires for any visible wear, etc..
SPLAT
Mar 8, 2009 07:05 PM
inthezoneac
Nov 10, 2008 03:08 PM
mill$civic
Jan 22, 2006 02:44 PM
