Failed Inspection..
Old Jun 24, 2005 | 06:06 PM
AnakinKenobe's Avatar
Default Failed Inspection..
Ok so i get the call today my 95 civic failed inspection, it needs a new Cat and a Cv boot, plus after all the head work and new dizzy i still got oil comin off my dizzy and i cant figure out what its doin.. any ideas for parts..
Old Jun 24, 2005 | 07:25 PM
Nail I3unny's Avatar
Default RE: Failed Inspection..
do you have stock cams or did you replace them during the head work?
Old Jun 24, 2005 | 11:24 PM
stock cam and cam gear..
Old Jun 25, 2005 | 08:10 PM
ok... well then its gotta be your cat. aftermarket cams with too much lift will make it impossible to pass inspection
Old Jun 25, 2005 | 10:15 PM
what cat do you suggest..
Old Jun 27, 2005 | 10:15 AM
still have that oil leak with a new head, any ideas anyone please....
Old Jun 27, 2005 | 03:00 PM
97CivicEX's Avatar
ORIGINAL: AnakinKenobe
I don't understand the question here. If you fail inspection, don't they tell you what failed? Inspection is when they do the visual right? Or did you fail the actual emissions test? As far as the leak. Where exactly is it coming from? What is your dizzy? Is that the distributor?
Old Jun 27, 2005 | 03:08 PM
i know what 2 pieces failed my car, i have a bad cat and a bad cv boot, but i have oil leaking from around the area of my distributor, its not my valve cover gasket i know that ...
Old Jun 27, 2005 | 03:15 PM
97CivicEX's Avatar
The distributor had an o-ring that might have gone bad already. That is the only other place I can think of that the oil may be leaking from. I was confused because the oil leak and CV shouldn't have anything to do with the inspection,... i don't think. Unless you are takling about inspection other than emissions.
Zunaro
Jul 16, 2008 06:26 AM
rx9790
Nov 23, 2005 12:12 PM
rx9790
Oct 28, 2005 11:30 AM
AnakinKenobe
May 11, 2005 09:31 PM
97b16swapcoup
Apr 25, 2005 09:38 PM
