Halo projection and regular headlights
Old Oct 19, 2008 | 12:20 PM
Projector, Reflector, Halogen, and High-Intensity Discharge (HID) are all different types of heaglight. Projector and Reflector both describe the headlight housing, and HID and Halogen describe the type of light emitted.
Reflector
First off, let's start with the Reflector headlight. Basically, a halogen (HIDs can be retrofitted) bulb shines in all directions. There are reflectors (basically shiny plastic) surrounding the bulb that direct the light in a general forward-and-down pattern.
Projector
Now, what exactly does a projector headlight do differently? More or less, it does the same exact thing as a reflector-housing headlight, with the addition of a condenser lens placed at the front of the light. The lens directs the light into a much more specific pattern, putting more usable light on the road. Also, projectors usually have cutoffs to keep the light from blinding oncoming drivers.
Halogen bulbs really don't require much of an explanation... they more or less work light a normal light bulb
HID headlights (also known as xenon headlights) uses an electric arc passed through xenon gas to produce light. Generally they're brighter and better than halogen lights, but they come with a higher cost, too. For the record, most oem HID lights are between 4000K and 5000K.
Also, it should be noted that most projector headlights have a projector light for the low-beam and a reflector light for the high-beam.
*images pirated from wikipedia... fair use ftw
Old Oct 19, 2008 | 07:49 PM
Flipz's Avatar
oh ok that clears up a lot, thanks!
hydnwtkns
15
Aug 3, 2009 07:18 PM
pimpossible
Oct 27, 2007 10:23 AM
Thefbomb13
May 29, 2007 12:11 AM
m00chness
Jul 18, 2006 08:54 PM
02civic
Sep 5, 2005 06:51 PM
