Here is one for you
Old Oct 18, 2005 | 03:59 PM
tpitts's Avatar
Default Here is one for you
Bought a '95 Coupe.
Check engine light was coming on and going off.
Speedo wasn't working so I changed the sensor and fixed that. Just bought it so I figured the guy that had it probably had never change the O2 sensor so I changed it also. Now the Check engine light stays on constantly. Car runs fine, just bugs the crap out of me.
any ideas?
T
Old Oct 18, 2005 | 04:03 PM
Remmy's Avatar
Default RE: Here is one for you
Have you trried resetting your ECU?
To do so, just simply disconnect your battery for 30 minutes (no less) and re-connect it and fire it up. If that doesnt fix it, then go to Advance Auto to see what code it will throw.
Old Oct 18, 2005 | 04:12 PM
tpitts's Avatar
I had disconnected it for 10 minutes or so. That being said, I thought I had reset the ECU.
I will try it for the half hour.
Thanks,
T
Old Oct 18, 2005 | 08:35 PM
mill$civic's Avatar
could it be a bad O2 sensor or a bad connection?
Old Oct 19, 2005 | 10:02 AM
tpitts's Avatar
OK. Reset the ECU and checked all the connections.
The light is still on. I had taken the car by Autozone to have them check it, but dude told me their code reader wouldn't work on '95 and older models.
Any other suggestions?
T
Old Oct 19, 2005 | 10:26 AM
Remmy's Avatar
Time to go to the stealership to test it.
Old Oct 19, 2005 | 02:37 PM
tpitts's Avatar
Default Figured it out
Checked my plug to see if there was any crud on the contacts. There was. Cleaned it off. Works now.
You'd think I would have checked that already.
Sheesh.
Thanks guys.
T
therobesons
Oct 1, 2008 02:51 PM
AOL.COM
Sep 5, 2007 04:46 PM
Bostonhoodhop
May 18, 2007 02:13 PM
windcalmer
Feb 12, 2007 12:59 PM
