honda civic 01 help!!!
Old Apr 30, 2009 | 08:12 PM
AutoNoob's Avatar
Default honda civic 01 help!!!
Hi Guys. Im new to this forum. Im a noob with cars. I have decent driving skills but i have very little idea what's inside the vehicle. Im going to post here pretty often. Hope i can learn a thing or two from you guys. hehe.
I brought a 2nd hand honda civic. Spend 240 dollars to fix the alternator. And i see the "SRS" light turned on. I have no idea what it is. Im not going to buy another 2nd hand car next time. Anyone here knows what it means and what i can do to fix it?????
Old Apr 30, 2009 | 08:30 PM
2nd hand car? what does that mean??
and SRS is Supplemental Restraint System i believe, it can be your airbags or other things set off the light too the air bags and the little pplug under your seat are the 2 i know about
WIKI INFO...
Things that can cause the SRS light to turn on include:
* Letting battery drain too low
* Bad Sensor
* Blown fuse
* Unplugging the car’s battery
* Removing the gauge cluster/installing aftermarket gauges
* G-Force sensors that are under each of the front fenders ($250.00 each)
* Bad clockspring (located inside your steering wheel)
* Bad ECU
* Bad reverse light switch on transmission
* Car was in an accident
* Airbag defective/unplugged
To fix this problem, some have gone to the dealership to have the SRS computer reset. Unfortunately, this costs somewhere around $70.00. Another option is to invest in a DRBII or MUTTII, which is what dealerships often use to diagnose and reset many of the car’s systems.
Old Apr 30, 2009 | 08:38 PM
The SRS light indicates a problem with the airbag system. You need to take you Civic to the Honda dealer, where they will retrieve the trouble code used to pinpoint the specific problem.
turnup_jermmms
Aug 14, 2012 05:47 PM
los666
Feb 23, 2008 09:52 AM
TDR05AL
Jan 18, 2007 03:21 PM
superballa22
Sep 18, 2006 05:06 PM
Jas10hon
Jul 4, 2005 10:35 PM
