Need help with gauge install
Old Jul 21, 2012 | 09:43 AM
Brandon Saletta's Avatar
Default Need help with gauge install
Hey i am trying to install a tachometer gauge and a vacuum gauge
on a 1996 honda civic and im having trouble knowing where to hook up the tube
to for vacuum and finding the ignition coil negative.
Any help
thanks
Old Jul 21, 2012 | 10:14 AM
Tachometer connects to the blue wire at the cluster. All versions have this wire even those without factory tach.
Vacuum you can connect anywhere on the manifold I suggest teeing into the hose to the cruise control or the purge valve (the valve inbetween the canister on the firewall and the manifold, tap the manifold side).
Old Jul 21, 2012 | 10:24 AM
Thanks!
Im not good with name for valves and stuff but would this hose be a good one to
hook it up to?
Old Jul 21, 2012 | 02:29 PM
Default Hose location
Honda Automotive Parts
Could you do it to hose numer 18?
Old Jul 22, 2012 | 11:38 AM
DaOne's Avatar
Yes 18 would work.
Faramire
Sep 7, 2009 02:27 PM
WhiteCivic98
Jun 3, 2007 09:08 PM
TurboToyzz
Feb 16, 2007 12:46 AM
dogma
May 18, 2006 09:58 PM
millertime17
Jun 26, 2005 09:38 PM
