Possible Damage?
Old Oct 20, 2007 | 10:42 AM
Partizan's Avatar
Default Possible Damage?
So yesterday I was just driving my ej8 with the stock d16y8 and i/h/e, and my gas pedal got stuck under my floor mat (yeah..wtf?) and the engine was bouncing of the rev limiter for a couple of seconds. I quickly shut off the engine while driving and stopped on the side of the road, and figured out what happened. I drove it afterward and everything seems fine, popped the hood and listened to the engine, sounds normal, but I am still concerned? So, could I have ****ed something up?
Old Oct 20, 2007 | 10:58 AM
cyberx32's Avatar
Default RE: Possible Damage?
Maybe some damage to the engine, but not too much, that rev limiter helped the engine not rev too high.. Just try not to do that a lot.
Old Oct 20, 2007 | 01:35 PM
foress_89's Avatar
certainly nothing at all, the redline is there for a reason, and the revlimiter too. You can rev your engine to the redline without danger IMO
Old Oct 20, 2007 | 02:08 PM
cyberx32's Avatar
sure if no danger means destroying your engine lol
Old Oct 20, 2007 | 03:47 PM
mxs's Avatar
mxs
the rev limiter is there for a reason... to KEEP you from revving into a range that will cause damage. it's probably fine. although you COULD tear apart the block if you want to check on everything......
Old Oct 20, 2007 | 03:48 PM
bouncing off the limiter won't destroy your engine if it happens once in a while. How long was it on the limiter? Did it bounce on it for a few seconds, or did you just tag it once or twice and shut the car off? It's when you keep bouncing it off the limiter that you get valve float. Personally, I'd say you're probably fine.
-and just because the limiter's there doesn't mean it's a good idea to keep bouncing off it.
Old Oct 20, 2007 | 04:43 PM
foress_89's Avatar
I'm not saying to bounce it every time you take off... I'm just saying that reving your engine that high once in a while by accident...
Old Oct 20, 2007 | 04:48 PM
t34me's Avatar
your fine
Old Oct 20, 2007 | 11:32 PM
Partizan's Avatar
Yeah it was just for a couple of seconds. Thanks for the responses guys.
99lx
Feb 16, 2007 09:19 PM
OHCD
Jan 5, 2006 12:47 PM
RedCityRunner
Feb 4, 2005 11:46 AM
C00T3R_Punk
Sep 29, 2004 10:53 AM
kngflp
Aug 27, 2004 12:04 AM
