Rear License Plate Bolts/Screws
Ok i bought my car from Adessa if anyone know what that is lol(Auction) and it came wit these stuupid *** screws the don't fit and i went to Autozone and bought the license plate bolt kit and they fit perfect for the front but they don't fit the read where can i get some that fit perfect .. my rear license plate is all loose its not going no where but its like a flap and it bothers me
Go to a hardware store and tell them that this: 8x1.25 is the size machine screw that "should" fit the hole but it doesn't. So then as for a self-tapping screw that is slightly larger that the 8x1.25. There are manly self tapping screw to choose from. I suggest a fine thread screw. Good luck!
If you use self-tapping screws, you could RUIN the mounting area. You just need to find the right screws. If the screws you have are too small, go to the hardware store and get some slightly larger ones. If they're too long, get some shorter ones.Two little screws shouldn'tcost you more than a buck.
If the threads in the mounting point nuts are destroyed, you may be able to run a tap through them and useslightly larger screws. I also use washers on the screws when mounting my plates.
