Removing heat shroud lower bolt
Old Feb 1, 2013 | 03:59 PM
jockellis's Avatar
Default Removing heat shroud lower bolt
Anyone got a good method of removing the lowest bolt on the heat shroud? I've got it loose but it doesn't seem that it's removal should be that big a deal. However. The radiator fan seems to want to get right next to it. Oh, yeah. How do you get it back on?
Old Feb 1, 2013 | 06:09 PM
It's not hard to take the fan out. Unplug the electrical connector, remove the bolts at the top and pull upward. There should not be bolts at the bottom, just clips.
Old Feb 2, 2013 | 09:19 AM
jockellis's Avatar
The air conditioning hoses sure pose a problem. But I got the shroud up enough that I could get my hand in easily. Before the bolt had turned 360 degrees, it was loose enough that I could then use my fingers to get it out.
Now if I can just get the shroud over those same A/C hoses...
jds62f
Apr 25, 2010 06:01 AM
dave_57204
Jan 10, 2008 05:39 AM
domestic disturbance
Jan 15, 2006 06:57 PM
plc00133777
Oct 26, 2005 11:04 PM
plc00133777
Oct 21, 2005 07:33 AM
