replacement OEM wheels
Old Aug 20, 2019 | 11:10 PM
caljac51's Avatar
Default replacement OEM wheels
Hi! new to the forum and new to taking care of my son's 2013 civic sedan LX 1.8L gasoline engine. Does anyone know which width wheel were originally sold with the new car. 6 vs 6.5, or even 4 inches.and also the hub diameter. I found most other info (PCD, offset etc) from wheel-size.com (I assume it is reliable) . running 195/65R15 tires on it. Also, can the same tire run on 6 and 6.5 inch width wheels? Thanks for any help for the newbie. Glad I found this resource.
Old Aug 21, 2019 | 06:38 PM
drakon543's Avatar
15 X6 diameter and width
5-114.30 bolt patten
offset is 41
as for your other question they came as 6 and 6.5 with a steelie or an aluminum. the aluminum is 6in only. not sure on hub size. same tire size is listed for both.
Old Aug 25, 2019 | 11:44 PM
martin392's Avatar
caljack51 here is a complete guide about wheel size of Sedan (https://www.wheel-size.com/size/honda/civic/) all technical details you find about wheel sizes, before buying any wheels for you sedan you may confirm the details here. I recently got continental tires for my truck and I am using that for 24 Hour Towing in New York, the performance of the tires is perfect.
etsherman
Sep 25, 2011 12:44 PM
MagTris
Sep 8, 2010 06:18 AM
denny8569
Feb 14, 2010 10:01 PM
reaper2022
Jan 11, 2008 02:47 PM
kelleykid
Aug 19, 2007 04:45 PM
