Stud thread problem
Old Oct 27, 2008 | 08:24 AM
ericchile's Avatar
Default Stud thread problem
I fixed my ebrake this weekend and in doing so I can't get one of the lug nuts back on without torquing the heck out of it. It looks like there is a small bur on the end of it. Can I get a thread chaser to clean it up ? If so what sort of thread chaser do I need for the stud?
As a back up, if I take the brake pads out again can I pound the stud out with out removing anything else? I already replaced one of the front studs by grinding down the hub and that was a helvof job...
What are the best lug nuts to replace the oem ones. Nothing fancy...
Old Oct 27, 2008 | 09:26 AM
ShaTownCivic's Avatar
This isn't off topic!
Old Oct 27, 2008 | 09:42 AM
ericchile's Avatar
Im sorry is this not the right area?
Old Oct 27, 2008 | 09:59 AM
Well now it has been moved. Thanks admins
Old Oct 27, 2008 | 10:25 AM
Rear studs are easily replaced. Worst case you would have to remove the bearing nut and take the hub off of the car, but I think you can get them out while the hub is still in place if you remove a few of the brake parts.
Old Oct 27, 2008 | 11:00 AM
ericchile's Avatar
Has anyone fixed a thread before with a chaser? If so which should I buy?
Old Oct 27, 2008 | 11:57 AM
It's just a metric die. I think the studs are M10. Yes that will fix it but if the whole thing is torn up from being cross-threaded, there won't be much metal left when you're done.
You can buy a new stud for a lot less.
Make sure it's not a bad nut too. Overtightening the nut will bend its tapered part and mess up the first thread.
Old Oct 27, 2008 | 01:00 PM
ericchile's Avatar
I am replacing the nut... but I can see the first two threads that seem a little scraped. If I can fix with a 10$ die, then that beats the 2-3 hours it took me to get the rear drum and pads etc apart and back together this weekend..... I am thinking time wise it is a lot faster... but yea if I could replace the bolt quickly for $2 it would have been done already...
Old Oct 29, 2008 | 01:48 AM
TheJGB3's Avatar
The thread size is 12mmx1.5
joven
Mar 14, 2011 08:24 AM
MaximusFunk
Aug 25, 2010 06:07 AM
markruscitto
Jan 15, 2010 05:35 PM
RoadRageCivic01
Aug 17, 2006 08:42 PM
Jippo99
Mar 22, 2005 07:00 PM
