time for new brakes
Old Jun 2, 2008 | 04:02 PM
pennstateED's Avatar
Default time for new brakes
my brakes are shot
looking into different things
slotted / drilled rotors? which is better or more preffered
like what do you ppl have
any good reviews or suggestions and/or what to stay away from
thanks
Old Jun 2, 2008 | 04:48 PM
Mr Mobsta Man's Avatar
Default RE: time for new brakes
Get blanks.
Old Jun 2, 2008 | 07:12 PM
cyberx32's Avatar
stock works fine for me
Old Jun 2, 2008 | 07:50 PM
macbeth18288's Avatar
+1 for blanks
what type of driving are you doing that would 'require' slotted or drilled?
Old Jun 2, 2008 | 08:37 PM
Live_4it's Avatar
Unless your engines built or boosted stock is fine unless your rotors are warped. If they are warped you can also get them grinded down, they just shave a little off so that it's flat again.
Just get ceramic pads, less road noise, lasts longer and less brake dust, as well as little better stopping power.
Also check your brake fluid level, if the pedal goes to the floor befor it stops brakeing or you have to pump them than you might need to flush the fluid.
Old Jun 2, 2008 | 09:25 PM
Kommando's Avatar
ORIGINAL: pennstateED
my brakes are shot
thanks
Forget drilled rotors. They aren't as effective at clearing gas/water/debris as slotted, while they have similar reduced surface/mass for shedding heat. Vented blanks work fine with ceramic pads.
You'll also get a better pedal feel with braided stainless hoses, flushing, and bleeding.
jonsaidthat
May 30, 2010 09:30 PM
NyTreCivic
Sep 30, 2009 05:33 PM
00IntegraLS
Jan 18, 2008 09:54 AM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
