'00 DX 4 Door exhaust question.
Old Mar 26, 2007 | 01:10 PM
FlipHKD720's Avatar
Default RE: '00 DX 4 Door exhaust question.
catback for 00 EX + high-flow cat/test pipefrom 00 EX and you will be set,end of story will bolt right up (althoguh you might get a CEL, depending on the secondary o2 sensor).
and IMO RSR is awesome stuff, soooo smooth.You won't regret it. YouTube some audio clips of it.
Old Mar 26, 2007 | 01:34 PM
cderalow's Avatar
ORIGINAL: FlipHKD720
if he retains his factory header, he's got 0 chance of throwin a cel, as he won't have done anything to the o2 sensors
ORIGINAL:js5184
So I should just get the RS*R which is "meant" for the 2 door and buy a test pipe that would bolt up to my factory piping in the midsection of the car and hook up the catback from there on? thanks.
yes
Old Mar 26, 2007 | 01:38 PM
StifflersMom's Avatar
Cat Fuсker
You might run into a slight problem if the flanges on the exhaust and the test pipe don't line up....nothing an exhaust shop can't fix quick and easy.
Old Mar 26, 2007 | 01:39 PM
FlipHKD720's Avatar
ORIGINAL: cderalow
true. i recommend getting a header if youre gonna be doing the entire exhaust system though haha and then he'll be in the DX/seconadry o2 sensor situation [:@]
Old Mar 26, 2007 | 07:15 PM
js5184's Avatar
allright thanks alot for your help guys, one last question...I see alot of test pipes on ebay that go for real cheap...I see some OBX's too...is it safe to just go for the cheap one's or should I get the OBX? thanks.
Old Mar 26, 2007 | 07:48 PM
Cat Fuсker
I had the cheap one and it worked fine.
Old Mar 26, 2007 | 08:25 PM
cderalow's Avatar
cheap ones will indeed be fine as long as you retain your stock header
Old Mar 26, 2007 | 09:57 PM
js5184's Avatar
yeah that's what I'm going to do then, leave my factory header with it's cat and buy bolt ona test pipe off ebay, put it on the midsection where it's supposed to go and buy the RS*R catback. hopefully everything plays out well and it won't be too long then, lol.
Old Mar 28, 2007 | 10:28 AM
cderalow's Avatar
ORIGINAL: js5184
if it's too long, you'll only have to take out the test pipe at least, and won't have any downtime while you wait on a part because the exhaust you bought is too short
FRESH96
Dec 12, 2007 09:18 AM
Koala
Oct 12, 2007 09:38 PM
rcr510
Jul 3, 2007 02:03 PM
datasunny
Mar 24, 2007 11:09 PM
mrsuburban
Feb 11, 2007 07:43 PM
