4-2-1 vs 4-1 header
Old May 20, 2004 | 10:03 AM
niteryder's Avatar
Default 4-2-1 vs 4-1 header
<FONT face="Times New Roman, Times, serif" size=3>i have a choice between a dc 4-2-1 header and a 4-1 dc header...which should i go with, or does it matter?</FONT></P>
Old May 20, 2004 | 02:25 PM
green98lxsedan's Avatar
i would guess they are gonna pretty much be the same. if so the difference will be negligable.
Old May 21, 2004 | 08:01 AM
polo708's Avatar
The 4-2-1 is just what it says...4 pipes into 2 pipes... then into one out to the exhaust. It separates the exhaust flow a little more and might give u a few more horsepower (maybe 1 or 2 tops) . 4-1 is 4 pipes directly into 1 pipe... </P>
Its kinda like the freeway, if2 lanes are trying to mergeat the same point, its alot easier on everything than 4 lanes trying to merge, does this make sense?</P>
If u can afford it... go with the 4-2-1, but if u are doing minimal mods then the 4-1 wont really hurt anything.</P>
Old May 21, 2004 | 10:39 AM
niteryder's Avatar
thanks for the input guys.
Old May 22, 2004 | 01:48 AM
Wheelbroker's Avatar
Default RE: 4-2-1 vs 4-1 header
Did you ever go to the start of this original Headers and Exhaust forum, I started it a while ago and posted a 4-2-1 Header in it.
Take a look at it and then if you wish e-mail me back..I'll answer your questions for you..
WheelBroker/Ang
Old May 25, 2004 | 06:23 PM
NTX's Avatar
NTX
If you can get the 4 to 1, get it.
Old May 28, 2004 | 05:09 PM
Struletz's Avatar
I would go with the 4-1, if you talk to any real racer it gives you the better ratios and HP.
-Struletz
Old Jun 30, 2004 | 11:08 AM
sacicons's Avatar
the 4-2-1 is better for midrange power and the 4-1 is better for top-end power, if you are into auto-x or circuit racing, go with the 4-2-1, if you are more into drag, go with the 4-1. that said, the difference isnt that big, just try to get a quality header in either configuration
Old Jul 2, 2004 | 03:21 PM
dc5pro's Avatar
4-2-1 is better mid- range power the 4-1 is a better top end set-up
curlybandit
Jul 18, 2007 01:25 PM
Jimmywah
Jul 10, 2006 02:35 AM
Peter_jai
Aug 18, 2004 12:13 PM
JayMan
Jul 23, 2004 09:05 PM
