Adding a catback exhaust loses power ?
Old Aug 31, 2006 | 05:08 PM
txedomask433's Avatar
Default Adding a catback exhaust loses power ?
I heard from anoher forum that adding an exhaust system may actually steal power from your car. is this true ? I was thinking of buying a meganracing drift-spec catback ex. for my 99 civic sedan but i don't want to lose power ! Also, is Megan a good exhaust co. ? I was looking for a reputable catback exhaust around $300. thanks guys.
Old Aug 31, 2006 | 05:22 PM
pWnEdU's Avatar
Default RE: Adding a catback exhaust loses power ?
You loose some torque with an exhaust, but most mods that increase HP sacrifice some torque.
On a naturally aspirated engine, 2.5" or greater MAY actually loose some power because the exhaust velocities are so low.
Old Aug 31, 2006 | 05:32 PM
so should i look for a smaller diameter of piping ? less than 2.5 ?
Old Aug 31, 2006 | 05:42 PM
ef4life's Avatar
2.25 -2.5 are fine for a honda engine that is na. if you have plans of turboing your car larger than 2.5 is pretty much a must to gain maximum power.
Old Aug 31, 2006 | 05:47 PM
thanks guys. I was looking around and saw that they offer an axleback and a catback. What's the difference ?
Old Aug 31, 2006 | 05:48 PM
BillyB98's Avatar
if i were planning on staying n/a i would get 2.25". As for megan it is a good, quality brand IMO
Old Aug 31, 2006 | 05:56 PM
pWnEdU's Avatar
It is widely accepted that 2.25" is the most balanced size of pipe for the N/A 4 cylinder.
Axle back starts at the rear axle, and provides .0000000000000001 HP.
Cat back replaces everything from the catalytic converter back. Provides maybe 5hp.
Old Aug 31, 2006 | 06:04 PM
thanks ;D any suggestions on where i can find a good catback w/ 2.25 in piping ? and does the tip count in increasing/decreasing power. i found this one w/ a 4 inch tip. would this be any good for my 99 na civic sedan ?
Megan exhaust choice
Old Aug 31, 2006 | 06:19 PM
pWnEdU's Avatar
Do a search and look in the product review section.
Old Aug 31, 2006 | 06:23 PM
how bout' this one ?
