aem v2 intake vs. aemcold air intake
Old Nov 13, 2006 | 11:20 PM
ic892003's Avatar
Default aem v2 intake vs. aemcold air intake
planning to get cold air intake from aem but not sure aem looks better but more expensive, is the v2 a greater diffrence from regular cold air intake, which one should i get for 92 civic lx? also is it hard to put on by yourself?? cause i dont want to pay a professional to do this job.
Old Nov 14, 2006 | 12:27 AM
my05civic's Avatar
Default RE: aem v2 intake vs. aemcold air intake
you don't need a shop to install it. you only need some wrentches and some time to fiddle around the engine bay. don't waste your money on anything less than the best - get the v2. the dyno results show that its an improvement on the original. aempower.com is the official AEM site: you can find dyno sheets there along with instructions.
Old Nov 14, 2006 | 12:34 AM
ic892003's Avatar
thanks a lot would u also recommend a bypassvalve incase of water getting in the engine bay?
Old Nov 14, 2006 | 12:50 AM
D16z6's Avatar
bypass valve is overrated. As long as you got your splash guard and fender cover you should be fine.
Old Nov 14, 2006 | 12:51 AM
mxs's Avatar
mxs
you cannot get a bypass valve for the V2
my05civic's Avatar
ya, you would only need a by pass vavle if you drove in like 7-8 foot of water. seriously. plus, with a bypass vavle, you kill the gains. with the aem v2, the bypass valve isn't compatible
Old Nov 14, 2006 | 01:10 AM
mxs's Avatar
mxs
it's more like 18" of water (if you're on stock suspension ) -- on my car at least, I think the design is similar on the 92-95 models.
Old Nov 14, 2006 | 01:25 AM
Misha's Avatar
ORIGINAL: my05civic
Are we talking submarines?[8D]
Old Nov 14, 2006 | 01:29 AM
my05civic's Avatar
ORIGINAL: Misha
ORIGINAL: my05civic
piff, i thought everybody drives on 28" DUBS and has their car raised 4' off the ground...
Old Nov 15, 2006 | 12:05 AM
ic892003's Avatar
i have a body kit that has the front grill a little open, can this increase the risk of water flowing into my intake system??
