cat!!!
Old Mar 23, 2010 | 06:23 PM
Yoba's Avatar
Exclamation cat!!!
been a while but, i need help!! im thinking about going with aftermarket headers...problem is i dont know if i can put a cat converter on it or does it have to be a straight pipe??? and would a catback exhaust even fit with a cat converter and aftermarket headers????
Old Mar 23, 2010 | 07:52 PM
Scott53092's Avatar
Most headers out there keep the cat, if they do not use the cat they will say they are cat delete. And cat back exhausts and header will bolt up to your cat no problem, the flanges will be the same as long as you match the system to your car.
Old Mar 24, 2010 | 12:24 AM
From reading your other posts, I have deduced that you have a 96 Civic DX.
If this is correct, getting a header will cause you to have no catalytic converter. As a result, you will throw a check engine light.
You need to convert to EX style exhaust to have a catalytic converter and header.
At the top of this forum section is a FAQ on the conversion
https://www.hondacivicforum.com/foru...ad.php?t=73237
here's the install DIY
https://www.hondacivicforum.com/foru...ad.php?t=73504
Old Mar 24, 2010 | 01:51 PM
Yoba's Avatar
nice write up, but all ireally have 2 do is change 2 ex headers, add an oxygen sensor extension, bolt the cat converter and connect to the cat back right?
Old Mar 24, 2010 | 02:16 PM
no, the DX catback is too long, by the length of a catalytic converter. You either need to shorten the catback or install an EX catback.
Old Mar 25, 2010 | 09:08 AM
Overurhead360's Avatar
I'm in the process of doing this. lol. ( ihave been since last summer) things keep comming up and it keeps getting bumped down my priority list. like trust said when you convert it moves the cat from infront of the engine to underneath so you need longer o2 wires and such.
jjouet
May 22, 2006 05:07 PM
jusplayn85
Feb 24, 2006 08:17 PM
uk civhead
Jun 12, 2005 06:39 AM
fast93civic
Jan 5, 2005 11:05 AM
scottishpol
Dec 31, 2004 03:02 PM
