COLD AIR INTAKE, HEADER QUESTION, PLEASE HELP
Old Oct 27, 2006 | 02:07 AM
TheMoogly's Avatar
Default RE: COLD AIR INTAKE, HEADER QUESTION, PLEASE HELP
It looks like a weird short ram... your cai on that civ should sit below your battery right behind the fan... how did you get all of your pipes on a CAI to fit like that?!
Old Oct 27, 2006 | 12:02 PM
soldout712's Avatar
Member
Mxs here are the other angles of the engine.
[IMG]local://upfiles/15052/8F9E14DD27DF4C5BAD855983948D3C4D.jpg[/IMG]
[IMG]local://upfiles/15052/BD24C078F2EE4F9D812E755C95B8762D.jpg[/IMG]
Old Oct 27, 2006 | 12:53 PM
Remmy's Avatar
Wtf?
Dude, I belive you have the wrong intake for your car.
Old Oct 27, 2006 | 01:37 PM
soldout712's Avatar
Member
it works though, i think because i did it wrong it works alot better, my friend has an m3 with the intake and it didn't change as much as my car did by installing the intake, my 0 to 60 dropped one second on this, it was ****in amazing
Old Oct 27, 2006 | 02:23 PM
mxs's Avatar
mxs
how much COLD air do you get off the top of your upper rad hose?
Old Oct 27, 2006 | 02:32 PM
My04Civic's Avatar
Administrator
ORIGINAL: mxs
RETURN IT! you got the wrong one it looks like (what Remmy said) get a better one!
Old Oct 27, 2006 | 03:02 PM
civicexracer's Avatar
uhhh ya return it or something. its sucking up all the heat coming off of the radiator hose, header, and engine. faaaaar from being a CAI. looks like u might be able to take a hacksaw to the pipe and cut enough to fit the filter down where its supposed to be.
Old Oct 27, 2006 | 09:28 PM
soldout712's Avatar
Member
is the air from that area bad, because the car picks up wonderfully, i dont think it would be better to fix it, unless the air is damaging it.
Old Oct 27, 2006 | 09:31 PM
its not bad, ur just sucking in a lot of warm air. u want to suck in cold air, thats the reason why ppl buy CAI's, lil more power..if u think it picks up well now, it'll pick up a bit better if u install the intake the correct way.
Old Oct 27, 2006 | 09:33 PM
soldout712's Avatar
Member
ok, ill have to do that, ill try to move the tube around so it goes under the battery right?, but yea thanks
KraZyCiviC
Jul 29, 2008 08:31 AM
Method
Sep 9, 2006 10:24 PM
Bostonhoodhop
Aug 1, 2006 08:57 AM
Technician
Oct 12, 2005 09:23 AM
notyou
Jul 5, 2005 09:26 PM
