Custom Bent vs. Buying a new cat?
I see throughout the site that some people have custom bend cat's and some have brand name ones like magnaflow. What are the pros and cons of these and whats the performance differences? I do know that custom is cheaper, but not much else
custom bent cats? A universal Magnaflow cat should do you fine if you want one, but the only time you'd see gains is with the high-flow Magnaflow cat, and even then the gains aren't much.
ORIGINAL: SovXietday
Uhhh wha?
I have a custom exhaust, but you don't bend a cat.
Uhhh wha?
It's either just bolted or welded somewhere in your exhaust piping to contorl emissions and really doesn't need to be "bent" or anything; it's just welded in any place where theres 2' - 3' of straight piping.
Flip has a direct fit catalytic convertor that will bolt up to the downpipe and use the correct exhaust gasket. You can also get universal cats with different inlet/outlet diameters to fit your application. They work the same, it's just the universal one needs to be fabbed up into place on your exhaust.
addiction2bass
Jul 5, 2007 12:13 PM
