engine hesitation after fujita sri install
Old Dec 28, 2009 | 09:59 AM
tnewk12's Avatar
Exclamation engine hesitation after fujita sri install
Just installed the fujita sri for my 07 civic ex. I have noticed a significant hesitation in the motor when I go to take off. My rpm's drop to about 500 and almost stalls on me. It is a standard shift and I don't know why it is doing this to me, any suggestions and what i can do to fix? i've heard unhooking the negative battery cable and reseting the ecu. I'm not sure really what to do
Old Dec 29, 2009 | 12:52 AM
Were any sensors left unplugged after the installation, whether it be on accident or due to the new intake not having a place for the sensor?
Also, do you have the check engine light on?
Old Jan 3, 2010 | 05:49 AM
GReddy_Civic's Avatar
Snail'n Admin
As weird as this sounds, I had a similar issue way back before I boosted. I installed my Injen intake, but for some reason, I too had a hesitation. Turns out that by some weird coincidence, I guess I bumped my plug wires just right that it messed one up. Once I replaced my ignition stuff (ie dizzy cap and rotor, wires, plugs (theyre the cheapest to start with before you start divin into the distributor components)) then it cleared up. I mean, honestly, a hesitation in driving sounds more like an ignition/spark issue or you left a sensor unplugged.
Old Jan 4, 2010 | 08:34 PM
tnewk12's Avatar
thanks, i'll have to check it out better when i get time. i didn't notice any sensors that i bumped but i very well could have.
Old Jan 9, 2010 | 11:06 AM
conceptualpolymer's Avatar
That may be a loose clamp or pinched hose, allowing unmetered air into your engine. I would recommend that you go back and recheck all the fittings.
snaowke
Oct 20, 2008 03:47 AM
Danporges
Jan 30, 2006 10:26 AM
Amanda
Oct 11, 2005 01:48 PM
Auto98EX
Oct 1, 2005 09:46 PM
