Exhaust manifold Issue
Old Nov 14, 2005 | 07:58 PM
vr6slper's Avatar
Default Exhaust manifold Issue
Hey whats up everyone I need some help on an issue im having with my car. I currently have a 98 Civic LX thats has a cracked exhaust manifold which makes hurendous amout of noise when the car starts up. I went to a local mechanic and he said that part it self cost 700 because the car is CA Emmissions and has a CAT on the manifold. Are there any other alternatives that can be used instead of a new CA emmsisions maniolfolf thats cost to much money. I was thinking of just getting a set of headers which are alot cheap. What do you guys recomend. I dont want to race the car its just my dailu driver to work. I would apreciate all the help.
Thanx
Old Nov 14, 2005 | 08:16 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: Exhaust manifold Issue
first of all are you from CA?
Old Nov 14, 2005 | 08:24 PM
vr6slper's Avatar
Nope
Old Nov 15, 2005 | 12:34 AM
sacicons's Avatar
then go find a muffler guy who will weld up the crack. thats BS to say that. just make sure you keep a cat on it, and you should be fine.
Old Nov 16, 2005 | 07:53 PM
AOL.COM's Avatar
i had the same problem --i took off the heat shield & welded mine with a mig welder ---kinda tight gettin in there --but its quiet--for now
btw --the vr6 is a good motor --but i prefer the 1.8t --its about 95 lbs lighter about same hp
Old Nov 16, 2005 | 08:05 PM
Pete's Avatar
If you dont care about the performance aspect of it then just go get it welded @ midas or something. You COULD just get an aftermarket header, or one from a junkyard, but then you wont be able to use your cat (Ud have to buy a new one) and that will make your car much louder than it is.
Old Nov 17, 2005 | 02:35 PM
Nail I3unny's Avatar
aftermarket headers are usually cheaper than stock...believe it or not
mudhenFUF
Jan 16, 2023 08:43 PM
ohheynix
Apr 3, 2012 01:42 PM
FRESH96
Dec 12, 2007 09:18 AM
ELECTRON BLUE 2000
Oct 4, 2007 03:25 PM
FlipHKD720
Oct 15, 2006 02:14 AM
