greddy exhaust rubbing making noise
Old Apr 23, 2006 | 07:39 PM
highspeedspecialist's Avatar
Default greddy exhaust rubbing making noise
I have a 2000 civic ex and have a greddy on there from previous owner. The problem is the exhaust is rubbing again my rr brake line (the hard line) and other parts of the chasiss. I checked all mounts and rubber isolator and they are in good shape. Anyone else have this problem with their greddy?
Old Apr 24, 2006 | 08:54 AM
Default RE: greddy exhaust rubbing making noise
I have not had the problem. But, a possible solution might be to spend 5-10 bucks on universal exhaust hangers (the kind with 4-5 holes) so that you can adjust where it sits to try and avoid further rubbing
Got a pic?
Old Apr 24, 2006 | 09:16 PM
I will this weekend!
Old Apr 25, 2006 | 10:42 AM
mill$civic's Avatar
just another little clipit of info..i recently had a problem like this, i could here a slight rattle under the middle of my car like metal agenst metal..i got someone to shake my exhust wile i looked were the sound was coming from, there was a piece of metal that cover the exhust from the bottom of the car, i just took a hammer and bent it back..worked perfect
Old Apr 26, 2006 | 10:08 PM
Thanks for the tip^ but I can actually see where the exhaust rubbing against my right rear brake line
Old May 12, 2006 | 01:03 AM
b18c turbo civic's Avatar
got the same problem whit my evo2 get it on a lift lossen all the bolts get a friend whit a prie bar bend prie the part away from where its rubbing let him hold it like that and tighten everything up and that fixed at least my problem might work for you
Old May 12, 2006 | 01:49 PM
x2100's Avatar
Mine rattles somewhere in the middle.
Sometimes when I idle, and most of the time when I reverse
It's embarrassing and annoying
Old May 12, 2006 | 02:31 PM
mill$civic's Avatar
did you read my post?? it could be that piece of metal in the middle that shields the exhust from the bottom of the car, i dont no wall all a sudden it started rubbing on mine, but it could be it..its only flimsy metal, just get someone to shake your exhust by the muffler and look underneather
Old May 12, 2006 | 04:57 PM
x2100's Avatar
Yup, I have.
Thanks for the info
I'll try it out later
Old May 13, 2006 | 11:46 PM
94DXProject's Avatar
I had a similar prob with my last car. My mechanic heated the pipe with a blowtorch while another guy bent it with a pry bar. The car felt faster without the grinding for some reason.[8D]
nebrown1
Sep 29, 2008 07:06 PM
brian400ex
Apr 5, 2008 05:47 PM
ctakacs
17
Dec 9, 2007 07:15 PM
My04Civic
Nov 10, 2007 06:40 AM
mentaldis0rder
Apr 16, 2006 02:46 AM
